Sunglass holder mod idea.......
The weather hasn't been the greatest for painting, so I will have to go back and fix this up before I call it finished. For now it works, and it gets my dash back together so I don't look like I'm driving a stolen car with wires hanging out everywhere! There is nothing behind those panels now but about 8" of space and some wires for the USB outlet. I wanted to put my CB there, but there just isn't the depth to be had. I also had tried my hand at heating up some polycarbonate to bend/mold it to fit the opening where the ash tray/socket doors were but it did not turn out well at all. If I had an oven, and one of those vacuum tables it would have worked...maybe. Ha-ha!
This is the progress on my DIY Bluetooth module. I have a wiring diagram drawn up and will be running traces once I get some more free time. Its tough because my Bluetooth module is SMD, meaning it has very tiny spacing between contact points and doesn't exactly play well with this through-the-hole board. It might look big, but the voltage regulator I have mounted on there is about the size of a dime.
Speaking of which, this is actually a neat little regulator! It can take a 12-24v input and step it down, in my case to 3.3v but it all depends on what you set it at with the little pot. I've been using my 18v drill batteries to power up other things using one of these on the bench since I am too cheap to buy a power source right now. Well, that and I don't have room for one at the moment.
The wife has me working on a kitchen remodel and I think it might be the death of me! I was hauling some cabinets home and couldn't see the trailer in my mirrors well enough to tell if my straps had come loose. I was on the interstate and feeling a bit paranoid since the trailer doesn't have a tailgate. A button to switch on the camera would have been awesome, and that's what sent me down that path. I believe, and someone more knowledgeable can correct me, that to activate the camera I will just have to switch ground with the reverse input. A switch would fool it into thinking I am in reverse and give me the camera feed whenever I felt the need, like pulling a trailer loaded with cabinets.
Wow some pretty cool projects - honestly the headphone cable is great - looks like you can pull it out or push it back in as needed. I'm in an '09 so I have the input jack built in. Any reason you did not just stick a 12v USB plug right into the 12v jack?
On the on-demand rear camera, I do not know the answer to your question. But ultimately it's whatever happens electronically when the gear shift is in reverse, so my thought was just to figure out a way to replicate that signal, but if your idea works it sounds simpler...
I had an adapter in the 12v socket but hated having that bright blue LED shining all the time, and it blocked the door from closing when I wasn't using the cords. The plug I installed also has a voltage display, kind of nice since there wasn't one elsewhere in the vehicle and I have run my battery down leaving my doors open for too long. Weird because I had switched off the dome lights but it still drained the battery.
Weeks ago I sent an email requesting some information from Pioneer since they are the company that manufactured the radio for Lexus. They told me to ask Lexus. If the techs at my local Lexus dealership knew the answer would I be emailing you, the very people who built the dang thing? How hard would it have been to pass my email along to some engineer? I'm not even asking for trade secrets here, nothing that I can't figure out on my own given enough time, I was just hoping for some expert input since I am nowhere near an expert! Eh, rant over.
Thanks so much for the responses guys. I'm having a hard time deciding how and where to mount 2 larger toggle switches and I can't justify the switch pros given my level of use right now, but that panel on Amazon is reasonable.
Cringe I look forward to the reverse camera mod!!!
I just had a few minutes free this evening and finished soldering my Bluetooth module then got it into a project box so its ready to be tested/installed. I also was looking just now for a wiring diagram or forum post about the reverse camera. I found a post on a 4Runner forum where someone was installing a factory camera and it made me wonder if I need to supply 6v to get the camera on when I want it or if its a matter of switching the ground. Will probably need a relay to make it work. Definitely need to study a wiring diagram!
