Suggestions on pulling stuck #6 plug wire?
Lee's Summit, MO (KC)
I did a search on "spark plug #6" and found nothing.
I replaced all my wires and plugs last fall but couldn't get #6 out. I had problems with a couple others sticking, but was able to get leverage to remove them. I gave up on #6. Well, guess which one started to mis-fire last week.
Any suggestions on getting the stuck wire out?
I am heading out to pull the hood off now. Will check back in about 15 min.
Thanks.
I just laid a hammer down on the valve cover and used large pliers and leveraged against the hammer's handle. Popped right off.
Don't pull the hood off. Have you tried loosening the heater hose junction from the firewall to get a little better access perhaps? When I pulled my plugs a few weeks ago having them loose gave the a little extra "Wiggle" room. Especially the small metal cross pipe.
If you did pull the hood, hopefully you marked the hinges/bolts for an easy re-assembly.
Well, i didn't end up pulling the hood. After looking at it, it just looked like a 2 person job (weight + lack of leverage = problem). I did end up loosening the heater hose juntion from the firewall with a 10mm box wrench. Didn't get it all the way disconnected when I dropped the 10mm wrench down behind the engine and it pinched between the firewall and the engine. After trying to get it out, it fell again and it doesn't matter which direction I tried to access it. I can't see it or feel it. It is gone.
I got the wire pulled, by wrapping the wire around a breaker bar and using the top of the firewall as a leverage point. It popped up. Then I had to dig down in there for the rubber gasket that was siezed. Fortunately I had soaked the hole with PB Blaster last night, and the rubber came out. Got the plug out, and it looked to be toast. So....because you can't just buy 1 new wire, I will be buying toyota brand wires to replace these "top of the line" brand that seem to dissagree with the heat given off by the I6.
NEWS - while pulling the rubber intake boot off of the intake, it snapped!! Yes, that big thick piece of rubber gave out. 12 years, and heat, and humidity must have taken it's toll. $107!!! from Stealership.
So....I have a PM in to CruiserDan since I did not have any of these replacements planned out of this thin payperiod.
I hope you eventually found that 10mm. I'd hate to be the guy behind you when that thing falls out at 70mph on the highway. Ouch.
Trust me, my wife and I have talked about that thing falling out. Any ideas on finding that thing? I can't be the first person to drop a wrench between the engine and the firewall. I might try jarring it loose in the neighborhood.
PB blaster!:cheers:
