Sudden downshifting with A442F and help locating transmission wiring
LH, the two connector housings are immediately above the starter. You can see them in the photo in Post #16.
These two connector housings join the engine and transmission harnesses. They are susceptible to internal corrosion because they are immediately below the pesky heater hose and when it leaks/breaks, it sprays coolant on them.
Thank you very much for this write up and pics. I am waiting for my TPS to arrive then will definitely have to check out my wiring next. I just had a rebuilt motor and trans put in.
Originaly my trans was not going into lockup. And now it's "erraticly" shifting in and out of lockup and som gears between 18-25mph/ 35-45mph and 50-60mph
If your trans is freshly rebuilt, then that should take solenoids, fluid, filter, and friction plates off the table. I’ll bet you a gas station burrito it’s a speed sensor wire or the solenoid wires outside the trans..
What's funny before I had all this rebuilt my gauge cluster shorted out blew the fuse had to replace my speed sensor and I put in fresh wires for the speed sensor I guess I didn't know there's two speed sensors quite possibly only replace one of them I know the guy who did the swap on the motor and tranny said he refreshed some wires up underneath there because the transmission shop said it's possible that a wire was grounding out on the transmission and caused my overdrive to not lock up
Sounds like you have more than one problem...
I am happy to report that I was able to replace my TPS w/out having to take my intake manifold off like the mechanic told me had to be done. I am also more then ecstatic to report that the TPS has solved my erratic shifting issues. Case closed on to the next adventure!
That’s great news. Cruisers are exceptionally accessible. Review this forum and the interweb before paying for repairs. TONS of support out there to help.
