Suction sand blaster
Defiance Missouri
Has anyone used one of the suction sand blasters that attach to your power washer to remove old paint and rust from body panels? If so does it do a good job?
I have tryid one. It didn't work.
And if it did you would end up with newly blasted metal wet from water. You don't want that!
I had good results with mine. Had to unclog every 15 min. Uses lots of sand but my FJ40 frame came out very clean. It does make a big mess but so does regular blasting. Used on Frame then used on the front fenders Both worked well
Sometimes even no matter how careful you are you might tend to get a little moisture. Thats enough to clog any good blaster
