When the original parts were not available, what have you done to make it work?
Starting this thread as place to pass on information on substitute parts and sources for FJ40 parts that are “Discontinued”, “No Longer Available” or not in the current budget for your project.
Have you discovered parts from other model years or other vehicles that fit your FJ40?
Looking through old packing slips trying to find a part number and ran across a few items that might be useful to someone else.
Early FJ40 green & red dash lamp assemblies for turn signals and brake pressure warning to replace corroded no-longer-available lamps.
12 volt panel lamps with chrome bezels:
Lamp assemblies from ElecDirect industrial supply, ElecDirect.com.
Green lens lamp assembly Cole-Hersee PL-20-GC000-BX
Red lens lamp assembly Cole-Hersee PL-20-RC000-BX
Substitute Brake Master Cylinder for early FJ40 with power brake booster and front disc brake conversion bolts to 1972 vintage brake booster.
No proportioning valve required.
Non-ABS Brake master cylinder from later model Toyotas.
1993 to 1994 Landcruiser non-ABS
1993 to 1995 4-Runner "
1993 to 1995 Toyota pickup "
1994 to 1998 T-100 "
Centric part number 130-44720
