SUA + 34x12.5s
I was going to try to fit 35x12.5s and stay SUA but I just didn't see it happening without LOTs of hassle. So, I went 34x12.5s
The truck already had a 3.5" OME suspension lift. I added a 1" Rodger brown lift. The install can be seen here:
https://forum.ih8mud.com/showthread.php?t=35741
I want to take small steps to get there. Nothing too drastic. Knowing the tires would now "fit" I ordered Pro Comp's rock Crawler wheel, 6 on 5.5 bolt pattern, 3.5" backspacing, 15x8.
For the tires I decided on the Trxus M/Ts, 34x12.5.
Here are the pics...
I did have to grind the front calipers ever so slightly as the stamped steel did rub them. Need to get the mudflaps off as well and of course, address the rust bubbles on the rear wheelwell. :mad: :mad: :mad: :mad:
The flex pics will come this weekend hopefully. Drove it 1hr home. Surprisingly quiet (relatively) and smooth.
Looks very good. Get it MUDDY!
DocB said:
Looks correct: the right lift to tire size combo. Why take off the mud flaps? They are functional.
i guess i should see how the tire fit when articulated with them on first. i just assumed i would need the room when flexing. also, here in ne england they just trap snow and salt, but also keep it up off the body. most are almost ripped off anyway...
looks great!!
:D :cheers:
Pete, how did the tires balance up? Tie rod clearance on the front will make the use of small wheel weights necessary on the front. Use a big weight that doesn't clear and you will hear a few thump-thumps as you pull away from the tire shop and then the front will feel like it's not quite right when you get up to speed. Happens with LTBs anyway and it will be interesting to see how the Truxus balance up.
If you get a change it you could take a tape measure and measure how high they ride off the cement that would be awesome. Also what is the width of your tims. I have a feeling those measure about that of a regualr 35. My 35's on cement mearue about 33.5" or low 34" with the tire off the ground. Thanks!
They balanced like hell. There are weights all over the place. The ones on the inside did clear the tie rods, we checked. I heeded to the advise of the LTB people on that one. So far so good.
Cookiemonster said:
ONE WHEEL WEIGHT PER SIDE wish mine did that
No way Jose... There are weights everywhere... Inside and outside lips on all tires.
lowtideride said:
trucks looking sweet bro....how much did them there tires run ya?
$169 per
the rims are 8"... how do you want me to measure? with the weight of the truck on the tire? I will go measure that way... 28lbs in the tire.. i'll come back and edit.... EDIT: about 33" 33.25".
The Truxus is the only tire I've seen in 34x12.5. Is there another one out there?
plainolejeff said:
Hey Pete,
What's up. Nice Lift. How's the rubbing with the 34's? I'm looking into a 4" inch lift with 33's. Thanks.
There is no rubbing yet at all. I have not flexed it yet though.
If you run 33x10.5s and 4" you will be fine for sure. I know one guy that has the OME suspension and 33.15.5s and he *barely* rubs, in the rear i think.
