- Joined
- Dec 11, 2006
- Threads
- 3
- Messages
- 8
...but, where is the fill plug for the transfer case. i think i have located it but im not sure. is it the bolt that is just left of the driveline on the driver's side? also what gear oil should i use? 90w?
I'd say yes. Sounds like you are correct in both Qs. I believe it is about a 17mm left (drivers side of the t-case) about even with the bottom of the driveline. Should be pretty obvious which one it is. 90w is fine. I used to use 85-140 from the tractor store but it got WAY to thick when it got cold so I went back to just 80-90w.
PS Which coast are you on?
Some insecure eastern washingtonians call people who live on the west side of the cascades "coasties". Most of us over here are like, "what? people live in eastern washington? why?"![]()
