Stupid Headlight Question
PNW
Ok, no question is supposed to be stupid but....
I need brighter headlights on my 1989 FJ62. I searched this forum and found a lot of references to replacing my stock lights with H4 halogen 55/100. My stupid question is:
My FJ has seperate low and high beam headlights (or so I think, it is in the shop right now). It would seem like I need new low AND new high bulbs. JC Whitney mostly has the 55/100 combo.
What am I missing?
Scott
Your "low" beam is an H4, which is actually low + high. Your "high" is an H1 bulb. See the following link for additional info:
http://www.SPAM website/hella/165mm_lo.asp
I used the Hella round H4's on my 60 for a few years, and recently switched to Cibie from Daniel Stern:
http://www.danielsternlighting.com/products/products.html
It clearly throws better light on the road. The Hella's were 5X better than stock, and the Cibie's were 5x better than the Hella's.
Note: you'll be better off with an upgraded harness. You can run the OEM wiring if you stay with stock wattage bulbs - though you'll get better light output with a relay based harness. However if you want to run higher wattage bulbs (well worth it in mybook) then the upgraded harness is mandetory. Do a search on here for the info.
There is lots of info on here about improving lights.
Note on upgraded bulbs - buy good ones. Don't go crazy. Aim 'em well and you'll be safe, and others will be able to see fine.
HTH.
