Stumbling rumbling problem.
Milwaukee, WI and Louisville, KY
Hi All,
Had an interesting morning with the cruiser (91, 204K) yesterday. After it sat all night I went out to run a few errands. After starting the truck and driving away I noticed a very pronounced stumble and rumble happening. The truck drove but had a lack of power and vibration. Felt like to me it was coming from the drivers side and back of the engine. (almost under the pedals) As I took it for a couple spins around the block it seamed to clear up to the point that I felt comfortable driving it around town.
Since yesterday I have driven maybe 100 miles with now issues returning, including letting it set overnight.
I do have what sounds like a little exhaust rattle in that area. Has been like that for awhile. Only in drive. Goes away in neutral or park. Could that be related?
Thanks.
could be a bad fuel injector. that causes hesitation and rumbling sometimes. when is the last time you changed your fuel filter?
maybe a bad cat, but not always likely. when did you change your o2 sensors last?
could be an ignition problem too. check plugs, wires, cap and rotor for signs of carbon tracking. or check the ceramic around the plugs for signs of moisture contamination or cracked ceramic.
there could be several different problems relating to a slight hesitation and a mild rumble. did your rpms fluctuate?
Did you wash yer engine recently?
I cleaned mine up last week and was in too much of a hurry to cover the distributer.
Blinking CEL and the motor was trying to jump out of the truck.
I pulled all the plug wires and blew them out with air.
Then the dielectric grease.
Then the Crusher running as it should.
HTH.
I am in Milwaukee, so you can PM me if it comes back and I will help you figure it out.
The RPM's didn't seam to jump much. I have not washed the engine and don't know how old the cats are. Could they be part of the rattling problem I'm having? Where are they located at?
Another side note. I had the truck in to have the trans fluids changed and flushed. After the mechanic drove it, he thought the truck was feeling a little sluggish. More than normal.
The check engine light never came on.
check your tranny fluid level. is the tranny slipping or shifting into gear real hard?
