Stud extenders work on pro comp shocks?
Does anyone know or has used the stud extenders on procomp shocks? Ive got the extended versions and still have a lot of space at the tops using 2" bump stop spacers
Thanks
Which Pro Comp's do you have? What are you sitting at for the shock length when you're fully compressed? If you have lots of space, why not just ditch the bump stops?
Ive got the 927530's on the front and 927XXX on the rear. They are the ones listed in the pro comp thread for lifted 80's. I tried ditching the bump stop spacer, well sort of, I went to 1/2" of washers and my 315's rubbed bad on full comperssion. So bad I bent the heck out of my relay rod(drag link) on a 3' ditch I didn't see going around a tree, bang, opps, bent rod. Shocks showed I had 1/2" left to go, just as I had inticipated, but thought I had wheel well room. No such luck. So the bump stop spacers went back on, waiting on new rod and ends, and thinking about using a 2" MT spring spacer instead of the rubber 1" I've got now. So I want to make use of the rest of the shock that isn't going to be used at the top of compression, move it to droop.
315's shouldn't really rub that bad, mine just barely rub, even with the poor man's 3 link setup (hitch pin mod).
Not sure why the tire rubbing would cause the relay rod to bend.
Anyway, you can use the stud extender to drop it down, it shouldn't hurt anything in the least. Plenty of people have run them. Alternatively, you could run a longer shock in the front.
If you stuff a tire, how much room do you have from the lower shock mount to the upper mount? 315's without bump stop spacers should be right around 16", so how much more room does your 2" dropped bump stops give you?
The rub didn't have anything to do with the bent rod, it was nicer to think it did than me just driving too fast around a blind corner and dumping the front end in a ditch @ 20mph. I left a real nice black streek inside the wheel well and actually heard the rub more than the bang of the rod bending. I don't think I really need longer shocks, just want to use the entire stroke of the shock as is. I haven't checked the shock mount length top to bottom, but when stuffed on the 2" spaced bump stop, I have 2 3/8" left of shock travel left over. If I space them down, I gain that 2" in droop. I do one huge problem though, in reading up on some other stuff, I found out my springs are swaped, I have "A" springs on drivers side and "B" on passanger side, both F&R. I need to swap the springs and recheck the stuff measurements, I have a feeling it will be different, but I still will have some uptravel in the shocks left over, it just may not be 2+" Do you think I f'd up my springs, been in for 3 months and about 2000 miles?
Edit: Do you think the reason for the bad rub is the longer spring is on the wrong side? I'm leaning toward that...
That's absolutely a factor. After swapping them, I bet how much left over travel you have will change as well, so I would re-measure to be sure you aren't over compressing the shock.
