Why not just bolt up eye adapters? You get a more rigid mount and you don't have a pin taking the force of articulation twist. Getting rid of pin style shocks is one of those "stupid factory design elimination 101" items
7100's use a spherical rod end - I doubt you could bolt them up and know you wouldn't want to for an application that really requires 7100's (I hear the "snap" now).
I was thinking pin-style to be able to run a shock that won't get "too long" after adding eye adapters on the axle and frame.
I may do the eye adapters now anyway since I will need a longer-travel shock.
I go to AZ twice a year, and could benefit from shocks that are customizable and won't fade out. I used to take-apart bike suspension in the early days to revalve when it was necessary.
Agree on designing around not fading. The more time I spend with the 80 the more I think it is a rig that will truly benefit from a very high end shock (in combination with the type of coil we have been discussing).
Look at the 7100 short body design. The AK7110SB model is a short body 10.25" travel shock that has .5" more travel than the standard FOR shocks plus a shorter compressed length by about 3/4"-1" if my "in the dark of my garage in a blizzard" tape measurements are reasonably accurate . You'd actually need a little bit longer eye adapters to properly match up that shock, or better yet raise the lower mounts as needed.
If I go 7100's at some point, this is likely the shock I will run, because typical 10" travel shocks are 16" compressed, and mine are closer to 15". I don't have an extra inch of travel left on impact, so bumpstops become an issue even going slightly longer.
What I would (and may) do with the 7100 is go with the short body and raise the rear lower shock mount. You'll need a non-metric stud anyway so might as well get some clearance. Up front, you can raise the lower shock mount with a simple spacer. This would tune up perfectly with the 3.5" kit for the usage you are suggesting, and I might think keeping the lift an inch lower on 35's with the high end shock is more suitable to your AZ high speed running than going higher with 37's. Good luck with it an do keep us posted if you go this route. I'll be curious on the valving you choose for the FOR springs if you get them.
Great info., thanks. I assume 2" lowered bumpstops are rquired. I don't have them now, and even with the gained downtravel of a longer shock, I am not crazy about losing uptravel, but may be a fact of life with taller rubber.
Yes, around 2" required. Remember that you aren't "losing" up travel. You are shifting the suspension travel down away from the body so that the range of motion is not so close to the body. This is why the non J/L OME kits can only run 33's unless you actually reduce available travel - the travel is all close to the body so even though a 35" tire fits perfectly well on a 3" lift, if the shock travel isn't designed for it then it doesn't work.
And of course, if you shift travel down you introduce a longer extended length requirement to the spring, this being much of the point of the ATS thread.
Bottom line is that eye adapters shift travel down by lowering the upper mount and compressing the shock. You could take any spring and work the shock travel in this way as long as you account for unloaded spring length, and that is the tough thing to do on the 80 rear suspension, because all things being equal the spring gets shorter as load capacity increases.
What I can tell you for certain is that short body 7100 will fit in the existing design parameters of the FOR suspension, and any tuning would be relatively minor in terms of micro travel adjustments, and then the rest is the actual valving tuning.
I need to stop posting to these threads, I'd like to do some of this tinkering but I just blew my limited 80 budget for the year on caster correction and my new stereo system . Some pretty good coin @ 170/ea, but I bet if you went 360/80 valving you'd have some pretty huge speed running performance in conjunction with the remote reservoir capacity.
That's a nice idea for the 5150.
The 7100's are welded on so it's not possible.
eye adapters are the most simple way to make the 7100's fit and it works well.
The downside is they are incredibly expensive so it's much better if you can just make them yourself.
you can see my buildup linked in my sig line. there are a 1/2 dozen others using 7100s as well.
Search w/ usernames: alia176, 450dude, landcruiserphil, clownmidget... it will lead you to a ton of info.
you may also look into FOX, as they have a newer post-style mount shock. The Jeep JK's use them. If you are willing to do the legwork and research, it may be a good bolt-in alternative.
Although I deal with Fox weekly at the bike shop, and arguably they make the best shocks for bicycles, to me, they are already too arrogant on the phone to deal with. I have blown Bilstein 5100's on my Nissans before, and they took care of it right away. I'll prolly stick with Billies.
After searching, it looks like The hardest part will be figuring out the rear lower mount and a source for the 90* elbows for the hoses.
