stuck windows
The windows on our 91 80 wont budge. The fuse is fine as the moonroof works. plus, just before they quit both of the rear windows came out of the channel that holds them. Is there a relay for the windows located in some obscure location not shown in manuals? Master switch- is there anything in that plastic box a screw driver and a 2 lb sledge can fix? Oh and another observation, the windows took frickin' f o r e v e r to roll up - nature of the beast? Small guage wiring?
Much obliged!
I've got a '97 but I think the set up is probably the same. Pull the master switch out (it comes out without any tools) and check the contacts. Connections go bad over time due to arcing. Cleaning the connections may help. That work for me the first time and is normally the cause of slowing windows. When my driver window failed completely it cost me a new master switch. I actually just had to put in a new motor as well. You can just run a couple wires to the window motors from the battery to make sure they work.
Do your windows work when you use a switch other than the master?
Hobbes is on the right track. Jumper the motors first to be sure they work. I've cleaned switch contacts in just about everything Japan makes and it often fixes it. Sometimes the power for right or rear windows goes thru the drivers switch. Also look at the safety switch if all or three of the windows don't work. It is rare that all motors fail at once.
Switches aren't made to be taken apart, but it is not too hard. Hold it together with two fingers and loosen the little bent tabs. Let your fingers apart SLOW. Watch for small parts that fly out! Clean contacts with fine sandpaper (600) and put it back together.
Much obliged!
I don't think the answer is in the switch. You are going to have to pull the door panels off and have a look in there.
Absolutely. Not uncommon for them to come out of the channel clamps. (Since the rubber guides are getting old/stiff/resistant, etc.) Tear into the doors, and put em' back where they belong (with a little silicone as glue). Then lube the guides as a temp. fix, or replace with new for a permanent one.
Hello,
I had this same prob w/ my passenger side front window. It went down all the way and didnt want to come back up. I took the door panel off (be careful w/ the plastic piece that fits under the interior door handle) and removed the entire power window assy. The problem ended up being a jammed gear, it seems the gear on the motor got misaligned w/ the elognated gear that actuates the window. Anyways, what I did this.
1. Lift the window to the up position. Find something to shim it, elsewise it will want to come back down.
2. Remove the motor/rail assy. (be careful, the rail assy has a spring to assist in raising the window. It may snap at you a bit)
3. Reassemble the motor/rail assy, making sure you have free movement.
4. Reinstall motor/rail unit back into the door panel, you will slide bottom of the window into the felt lined rail support for the bottom.
its a bit difficult to explain, but I think one can figure it out with a bit of time.
Good Luck.
James:)
