Thought I would post up in case anyone needed the info.
My fuel gauge was always reading empty. The light would come on when low enough so I knew the float was either bent or had a case of the crusty rustys. While in there I figured I’d replace the sock on the pump.
Sure enough the entire assembly was crusty and the float arm took some pressure to free it. I sprayed some penetrating oil on the pivot point and moved it back and forth freely. Seemed to work fine. Once I saw the sock I replaced the pump also because I’m sure it’s 23 years old! Plugged back up and turned the key to a working fuel gauge.
So if you have a sticky or non working gauge and the light still works, take a look in the tank before spending the $100+ on a new float!! And the sock is as important as the fuel filter!
