Stuck F
Edmond, OK
Well I'm working on my 40 that the PO had sitting for about 10 years. I'm trying to determine if the F engine is seized or not. The PO said it ran before he parked it. I took the radiator out today and got a socket for the "big ol nut" and can not move/turnover the crank. I don't want to try to start it because I don't want to damage anything if it is seized. I took out the plugs and put a little oil in to see if that will loosen anything up. Does anyone have any advice or tricks on how to determine if I'm in for a rebuild? Should I get a pipe for my 1/2" drive to get more leverage? Any help would be great.
Thanks,
Brian
A freind of mine just through some oil in like you along with some diesel and let is sit for about a week, then he broke it loose with a breaker bar.
Thanks,
Brian
The oil in the cyliders was going to be my first suggestion. Also I have heard of people fitting an airline into the spark plug hole and using compressed air to turn over a engine. Need to make sure you are above TDC.
Never tried it though...
I did this once... first get a 3/4 drive . A real man tool :D Put good penetrating
oil in the combustion chamber (no WD-40 please :rolleyes: ) Everyday, add oil and try to move it... It took me 2 weeks to make it move. good luck :beer:
I did the same with a 2 F that sat for 3 years. Pull all the plugs and get the wifes turkey baister. I used marvel Mystery oil as suggested and shot some in all of the cylinders. I am told and verified on my engine that you should be able to move the harmonic balancer by hand. But I would try the longer breaker bar.
Starter is not that strong. If damage will occur with it then the motor is already in bad shape.
Sqirt some Marvel/wd40/Kroil/PBBlaster in each cylinder and goto town...
