Stripped Manifold Stud?
Vancouver, BC, Canada.
Website
www.paool.com
78 Fj40, Stock 2f With Removed EGR crap.
Its the most fun one too! Its in the very very far back RIIIiiiight near the firewall. I can't even fit a 3/8'ths drive socket and ratchet in there (just the socket).. I might try it with an elbow, but I doubt it would work
Anyways this bolt wayyyyy at the back, seems like its stripped. but unlike any bolt I've ever stripped before (keep in mind I try not to make a habbit of it :D). It still has some bite too it untill a certain point, then it lets go and loses some tension. If the threads in the block where stripped wouldn't the bolt just spin freely and not go in or out? I'm hoping its just the threads on the bolt, and I can take it out if Its not tight enough and I have another gasket leak.
Me and a friend seem to think it *should* hold. But hypothetically, IF i stripped the threads on the block, how much work is it gonna be to fix this? I'm not much of a trouble shooter, so unless I find a set of taps that will fit in there, the only thing I can think of the rectify the problem would be to A) drill a hole in the firewall metal blocking my way (*might* be accessable from the inside of the cab where the firewall starts to concave). B) heat and bend the firewall metal in my way untill somehting fits. or C) Pull the engine out or at least up a bit to access the problem area. BOOO!
your thoughts?
I certainly wouldn't go through the firewall, and I don't think I'd try to modify the firewall to get to it either. I might try packing it full of JB weld, but doubt that would hold it. Best thing would be to see if you can get in there with a right angel drill and then helicoil it. Sounds like you are haveing too much trouble getting at it though, in which case, I'd pull the head and helicoil it. While it is off I'd tap and inspect all the threads in all the holes on the entire head, and go on and helicoil any that look suspicious. I chased all the threads on my entire engine after painting, before assembly began.
JamesM said:
ugh.. didn't want to hear that. But what can you do?
I'm just hoping its going to hold. its is pretty tight, but not TIGHT.
And whats with it getting tighter to a certain point then letting go?
Take it out again, and refit with hi-temp loctite.
It might stay there - you can inspect the bolt while it's out.
