stripped head bolt
Nampa Id
i just did a head gasket and timing set on my 85 pickup 600 miles ago. i went to retorque the head (63 ft lbs) and one of the head bolts stripped. well the bolt is fine, its the block threads that went. is there any way to fix without taking the head back off?
I had a block that the headbolt boogered the threads when I took it out. I did the helicoil and it did work for a while. I think a timesert would be better if you could find the size. I think it is a 12x1.50 thread. I still have a few helicoils left from that job!
Danny
I'd second the timesert. But before putting those bolts back in, I'd run a tap through EVERY head bolt hole... and then buy a set of ARP studs to prevent this from happening again.
where do you get a timesert. never heard of one b 4. :idea: what is it? A solid Heli coil? i talked to a shop that said they would put some sort of an insert, that was kinda like a heli coil but better, in it for a 100 bucks. if it goes in like a heli i will do it my self. they said they do alot of them and they hold good
#4
toyrunner
IH8MUD Rookie
TLCA# 7031
Posts: 72 I had a block that the headbolt boogered the threads when I took it out. I did the helicoil and it did work for a while. I think a timesert would be better if you could find the size. I think it is a 12x1.50 thread. I still have a few helicoils left from that job!
Danny
__________________
1978 FJ40
1985 4Runner
what do you mean by a while?!
+1 on the studs. www.engnbldr.com, talk to Ted or Todd. Best in the biz.
