Stray Vac Line ID?
Lower Alabama
1997 LX 450. Was going through the typical nothing else better to do undercarriage inspection when I saw this. A loose hose that looks like a vac line. These are definitely not the trans fluid cooler lines. It is partnered up around the drivers side floor board with another line the same size running into the top of the trans or TC. The first 2 pics is the loose line. The second is the line running into the top of the trans. Ive searched the forum a couple different ways and went through the FSM under all the topics I thought it might fall under. The only thing I can come up with is the supply line for the rear window washer but only because I don't know how that is routed. Couldn't find that in the FSM either. Any suggestions for what this hose might belong to?
