Strange Radio Static
Pampa, Texas
The reception on my radio has always been crap... and I've read that several other people have the same problem so I never put much thought into it.. but today I found something weird.... I'll have static, and when I turn my windshield wipers on, it goes clear as day... then off-static, then on-clear... I tested it for a few minutes.
Bad Ground?? what's up??
It's a Kenwood aftermarket unit that the PO installed and I've never had the dash apart, so I don't know what the wiring looks like.
Unless you're prepared to do it right, getting the coax through the firewall if it's removed without tying a fishline to it first in order to pull it back into the cabin can be a mother. If someone started off wrong on that when the installed the aftermarket headunit, it could be the source of problems. If the coax is cut in the process or, even worse, grounds to the body that way, that might be the issue.
A visual inspection to determine if the coax is properly routed might tell you something. Looking inside the right fender, you should see it go way back and high up, then turn abruptly to enter the cabin. Inside, the first thing to confirm is if the coax was properly plugged into the radio. The rest will be hard to see, but do what you can to confirm the coax is undamaged.
so if you were to pull your h/u out - this is what it looks like...
at most a :banana: job - requiring only Phillips screwdriver -
see the small black - silver tipped cable on the right - it is fairly long
check that is you antennae plug - check it for shorts -
it leads to the antennae / motor which is house in the PS fender well...
bF
I've recently purchased a unit to be able to use my CB antenna as my Radio antenna and get rid of the one in the fender and hopefully get better reception. So I'll be running a new coax cable anyways. hopefully that's my issue.
If you go this route, leave the coax from the current radio running to the stock antenna location in tact in case you ever want to change to need to fish some through that route. If you pull it out like mentioned it is near impossible to feed another through with a pull line of some sort.
I went the firestick cb/fm splitter route years ago. It works OK.
SNIP
Well, the fender DOES come off:hmm:...but you probably don't want to go there.:eek:
