Strange Problem after warmup
Hello all, This is my first post! I have been putting around this forum for a few weeks now and finally came up with a question I can't find an answer to via searches. Great group seems to dwell here.
I have a 97 SC'd FZJ-80 and started having some seemingly fuel related issues:
When the car is cold (just started) it runs great, no problems. As soon as the temp gauge hits near the middle the engine starts missing when the gas is applied. It will hit say 2000 RPMs and start cutting out, it doesn't die it just cuts out and runs for a couple seconds and cuts out again. If I let go back to idle, it has no cut-out or miss? Again if I let it sit for a few hours it starts up and runs fine until it warms up again. Seems like something involving the cold start system vs. the normal temperature is not switching? Also, not getting any trouble codes or check engine light (it works).
So far I have checked the fuel pump with a 12 volt power supply sounds good no "pulsing", I have cleaned the Fuel Pump Relay and tested continuity with power applied and off. Replaced the EFI Main Relay to no effect. Any ideas? Thanks!
throttle position sensor have any h2o lately?
If you mean has it gotten wet lately? No. Has the radiator been run low? No. Fluid levels are all good, I don't think a drop of rain has hit the car in a couple months and I haven't done any water crossings with the vehicle.
Bummer, looks like I'll be taking my wife's Xterra camping :frown: this weekend. I'll be working on this problem when I get back Monday. I'll get a chance to investigate the h2o issue further then. Thanks!
low batt voltage, Bad fuel pressure regulator, vacuum hoses not tight, pressure hose popped, clogged cats, bad O2 sensors, bad MAF, bad temp sender or wiring.
I'd ck cats and temp sender first.
SJ
94 SC
CJF said:
Don't discount simple things like spark plug wires. A bad wire can cause all sorts of intermittent, gremlin like issues.
Curtis
97 no codes. OBDII should issue a misfire code for bad plugs or wires, and define it as intermittent even. BTST. I suspect an actual drive with a code reader would identify the problem. I'd be going after the MAF readout.
SJ
After talking to Chris (5150) it ended up being a bad ground strap.
Hi Everyone. I'm having a similar problem and am wondering what ground strap may be a culprit in this scenario. How many ground straps are there? and where are they located.
Thanks in advance.
