strange noise when starting
97 LX450 making strange noise when turning ignition. it's a quick "buzzing" sound and then a quick sputter and it doesn't turn over. starts up fine when I try again. Any idea? is my starter getting ready to fail? getting ready for long road-trip next week and need advice. it's really cold (15 degrees) could that be contributing?
Thanks for any feedback.
Starter contacts and/or plunger. Keep a stick or something handy to whack the starter with in case it gets stuck, and a wrench to undo the battery cable if that fails.
If you let it run too long you can burn out the starter, or even worse catch your engine on fire.
does this happen only when it's first started in the morning, when the truck is cold? Or does it happen all during the day after it's warmed up a bit?
In cold weather, the battery will put out much less current than when it's warm, and of course, a cold engine actually requires more current to start, so several issues in your starting system could be causing this.
Check battery. You can do a load test, Autozone and other autoparts places can loan you the unit for free, or many auto shops will do this for free.
Make sure all (ALL) of your starter and battery connections are clean and tight. Both negative and positive battery cables, and at both ends of each. Battery clamps must be clean. Believe it or not, sometimes you can find a weak connection by feeling for heat! If you are starting the truck, the system is drawing a lot of current. Any weak spots will do two things: They won't pass all of the current, and they will start to heat up, fairly quickly. So after this happens, you could feel the clamps, and where the cables attach to the chassis, block, and starter, and battery. If one is warm, that's a bad spot.
The starter contacts may be starting to fail, it's pretty common on these trucks, but check the above first.
Another thing to look at is the "signal" wire from the ignition switch to the starter solenoid. It's supposed to deliver 12 v to trip the solenoid, but after years of use the ignition switch may be weak and only supplying 10v or so, and that may not be enough to firmly engage the solenoid. The way to check is to measure the voltage at that wire where it plugs into the solenoid.
Thanks for the valuable feedback. Turnd out to be the starter contacts. Replacing w/ reman'd starter.
