Strange idling/startup issues
the past few weekends when I start up the LC the check engine llight comes on the idle is ruff and when i press the gas pedal is first wants to stall before reving up. After two or three start up the engine behaves fine. Any idea what this could be...I replaced the number 2 O2 sensor and all was well for a few weeks.
Check you air hose for cracks going from the air can to the engine. Take it off and look in the grooves.
X2 on the intake tube. Are you still throwing a code? Is it O2 sensor, or have you checked? If your ECT sensor is bad, it will run the wrong mixture until you have it warmed up.
-Eddie
All of the above, plus your computor will store trouble codes, even if the check engine light has gone off. Simple deal, check the troubles logged into memory!!!!!
