strange F motor
Central MD
it just wont start??? i bought it about 2 years ago for 200$ (clean body 2 :) ) and i just finished my 60 off. i cant figure why this thing wont start. its so close to turning over but it just never ignites. even with the aid of starter fluid. So what steps would you all do to get this pup to run. i checked the electrical and there is spark to every cylender but its yellow. is it supposed to be a hotter spark? blue? im kinda running out of my usual tricks to get a motor to fire so nehelp would be nice. thanks
When I bought my non running 74 fj, it only took me a moment to figure out why it wouldn't run. Try looking through your oil filler port while cranking to see if your rockers are funtioning. If not, you will be looking at replacing your timing gears as some teeth off the larger gear might have taken perminant leave of absense, as they are likely to be made of a composite material.
Just one possibility, eh!
Make sure he timing is not 360 degrees out (distributor installed so it is firing during exhaust TDC
i think you mean 180 out, 360 would be in the same place bud............
Quess it depends if you are talking about the crank or the distributor:)
I should have been more clear
Diagnostics
I'd check the compression in each cylinder, that would go a long way toward giving you an idea of what condition things are in, and then verify that your timing is right. Odds are either your distributor is indexed incorrectly, or your cam timing is off, though that seems unlikely if it ran before you got it. Gears tend to either work or stop working, not slip out of time. You are getting spark so you know your cam is turning. May be worth confirming though, especially if the PO changed or pulled the cam gears.
Spark should be blue. And +1 about checking the 180/360 degrees off timing thing.
For that matter, make sure the ignition wires are in the correct firing order and that your ignition timing is set to run the engine (7-12 deg before TDC).
Does it try to light on the starter fluid? Maybe not getting gas to the carburator? Remove that crappy paper element from the glass bowl and try again. If that works then get a disposable in line element and splice it in some where.
Compression check is a good thing to check for much of what has been listed. If your timing gears are not working your compression test will give you some odd numbers.
If you don't have a compression tester ( no reason not to they are cheap) at least pull the valve cover and roll the engine through by hand and watch to see that all your valves are operating smoothly.
Also, check that all of the connections in your ignition system are clean. A little dirt, moiture, or corrosion could be affecting your spark.
For $200, it's a good deal even with a roached engine.
Also check the fuel cut-off solenoid at the carb
Could be 540* out, too. I had that happen once.;)
bretty said:
yah i called him bud, i didnt wanna call him bub!!!
Bub could have a gub. Careful.
Ed
