strange engine problem?
I am going to try posting this again. Maybe someone can help me identify what has started happenning on me 1995 fzj80. Problem only happens when the car is warmed up to normal operating temperature. The problem usually only happens when I am towing something. It will stall or loose power for just a second if the throttle is pressed too far, but if I back off the throttle it wont happen. All of the lights on the lower portion of the dash blink off and then come back on as if nothing has happen except sometime the check engine light stays on. When I check the code it is 340 (crank shaft sensor in my book.) Any suggestion or past experience that can help. Is it the crankshaft sensor? Thanks in advance.
Roy
Hmm... Kind of a shot in the dark, but check your intake tube for cracks.
My 80 had similar symptoms with a cracked intake tube; worked great when cold, but once it was warmed up it ran like crap.
Make sure you actually bend the tube... When the engine torques, it will open the crack and let in unmetered air. The crack can be closed when the engine is not being torqued.
I'd say that your problem is likely related to your Crankshaft sensor. It is difficult to fool the computer into thinking it has a bad Crank sensor by fiddling with the fuel/air ratio.
Perform the FSM tests for the Crank sensor and see if it is bad. Also, I'd check the wiring harness back by the firewall next to the EGR valve--your engine could be torquing to the side and shorting out something back there...
I went and checked as well as I could considering it was fairly cold and difficult to bend. No obvious cracks. Anyone know where the crankshaft sensor is located?
DTC P0340 Camshaft Position Sensor Circuit Malfunction
CIRCUIT DESCRIPTION
The camshaft position sensors (G1 and G2 signals) consist of a signal plate and a pick up coil.
The G1, G2 signal plates each have one tooth on the outer circumference and are built into the distributor. When
the camshaft rotates, the protrusion on the signal plate and the air gap on the pick up coil change, causing fluctuations
in the magnetic field and generating an electromotive force in the pick up coil.
The ECM detects the standard crankshaft angle based on the G1, G2 signals, detects the actual crankshaft
angle and engine speed by the NE signals, and detects misfire by NE2 signals.
DTC No.
Diagnostic Trouble Code Detecting Condition
Trouble Area
• Open or short in camshaft position sensor
P0340
No camshaft position sensor signal to ECM with engine
speed 550 rpm or more • Camshaft position sensor
• ECM
WIRING DIAGRAM
EG–286
ENGINE – ENGINE TROUBLESHOOTING
INSPECTION PROCEDURE
Reference INSPECTION USING OSCILLOSCOPE
1 Check resistance of camshaft position sensor.
3 Check air gap (See page IG–9).
2 Check for open and short in harness and connector between ECM and
camshaft position sensor (See page IN–26).
Disconnect camshaft position sensor connector.
Measure resistance between terminal 2, 3 and 4 of
distributor connector.
”Cold” is from – 10°C (14°F) to 50°C (122°F)
and “Hot” is from 50°C (122°F) to 100°C
(212°F).
Resistance
Cold
Hot
185 ~ 275
240 ~ 325
• During cranking or idling, check between terminals
G1, G2, NE, NE2 and G– of ECM.
HINT: The correct waveforms are as shown.
Replace distributor.
Repair or replace harness or connector.
Replace distributor housing assembly.
Check and replace ECM (See page IN–31).
ENGINE – CIRCUIT INSPECTION
EG–287
Thanks, lextech. Not sure I understand everything you posted. Anyone know if this malfunction I've described(Loosing power under heavy load) might make sense that the distributor (crankshaft sensor inside) is the problem? Any chance I can clean or replace the sensor instead of the entire distributor?
Thanks, lextech for the help. The info you posted refers to pages of the manual. Is info somewhere online I can go and view it?
