Stock Wheel base??
Nebraska
What is the stock FJ40 wheelbase? I purchased my FJ40 with the SOA and Shackle reversal already done, and I'm trying to figure out just how they did the SR, whether they moved the front axle forward, if they drilled the springs, etc. I know the military wrap is at the back now, so I'm assuming the springs were reversed, so does that mean they were also redrilled? My pinion angle is dead level, so the driveshaft meats the pinion at a pretty nasty angle. I am planning on rewelding the spring perches to turn the pinion angle up a bit, but I think the aftermarket driveshaft thats on there now will need to be shortened to do it, or I could just move the axle further forward, hence my original question, what is the stock FJ40 wheelbase. I took a tape measure to mine last night and it looks like it is roughly 92 inches........
Thanks
Tom
So then it probably has been pushed forward. Does this happen with or without drilling the springs? Can I go further forward? I could just drill another hole in my spring perch after I reweld right?
I checked it again just now and it is actually closer to 91 as it sits. Whats the easiest way to move my axle forward an inch or two so I don't have to shorten my driveshaft after I turn my housing up a bit??
Thanks
:confused:
No s***! I realize that's an option, i didn't fall off the fxxxing turnip truck yesterday, I was hoping for a little more info on the shackle reversal, like are they drilled, why is the military wrap in the back, blablabla, but i'll figure it out myself. I would hate to take up forum time from someone who's trying to figure out what sealer to use on their axle covers!
post up a pic of your shackle reversal...there are a few ways that they have been done over the years....all you stated was that one had been done, not how it was configured, or who's kit you thought was on there....it matters.
Good luck!
Here are some pics. Thanks for looking. Sorry for the attitude Poser! :)
Check it again please, I fixed the pictures.
Thx
For starters, it is a good thing that they just swapped the old hangers front to rear..with your SO set up...
I cannot recall off the top of my head the difference in center pin to spring bushing, front vs. rear on the front springs...but I turned mine around when I did a shackle reversal, and thought that I gained about 2"...I am SU, and using a MAF shackle reversal too...
I am not at the shop, and cannot put a tape on a stock Land Cruiser front spring pack and get Dims....perhaps someone out here has those #, or could measure them..
-Steve
Need an acronym breakdown on MAF please.
thanks
I'm busy sanding right now, then off to paint this weekend or next, then I have to wire it, reinstall the brakes, clutch master and slave cylinders, fenders, hood, dash parts. Assemble the cage, install a locker in the rear and have it in Moab first week in April. It's been like an episode of Monster Garage around here but had to watch the kids tonight so I thought I'd pimp you guys for a little info.
Thanks
Here is a chart from my 1975 Land Cruiser owner's manual.
HATTRICK:)
90 inches, got it! Thanks
the center pin of front and rear FJ40 spring packs is 3.5" offset...flip the packs end for end and you'll gain or lose 3.5" of wheelbase.
For just another inch, remove the packs, drill a new offset hole on the axle perch and drill another hole in the u-bolt plate. I added 1.5" of wheelbase to my front axle this way.
Thanks Woody! That helps alot. Since my wheelbase is only about an inch longer than stock AND my leaves are reversed, the PO must have redrilled the springs. I might just be able to reuse the stock pin location and take advantage of the full 3.5 inch wheelbase extension, or just drill another hole in my perch depending on what I need for driveshaft lenght after I roll my housing up.
Your steering scares me..
I doubt that the PO redrilled your springs.. those clips do not look to have ever been opened..
HOw are you measuring your WB? I bet you have the Full 3.5" available to you.
If you really want more WB, then redrill the spring perch and U bolt plate. Which will suck considering that you have U bolt skid plates on top of your springs..
Consider selling those and getting some stock U bolt plates..
500% more likely they just moved the front hanger an extra 2.5" rearward prior to welding it on.....no rocket science there....
Well,
Whatever you decide to do about your wheelbase, make sure that your front drive shaft has enough slip so that it will not pull apart on full droop, or trying to climb a face, and that it will not compress so much that it knocks the case off the transmission. I know that you are trying to avoid drive shaft modifications, but at the end of the day, you may very well work a lot harder trying to not spend money than you need to, and only end up in a position of needing to modify the front shaft anyhow.
Good luck!
-Steve
