Stock spring rambling
Cruiserdrew
On the way there
Sacramento, CA
I learned a lot about springs today, and I though I would post up, in case anyone else has the same observations or other comments. I am in the process of beginning the build on my 71 and have been acquiring parts. The plan is to do a SOA with Gravelmakers great beefy parts and with a few twists and turns. I am using FJ62 axles, outboarded FJ40 springs up front, and FJ60 springs in the rear to lengthen the wheelbase. The front will be shackle reversed, and the rear will use the stock frame mount, and new Gravelmaker rear shackle mounts.
I have always felt the need for more spring on my FJ40. With a full camping load for 3-4 days and my heavy bumper, the rear sits low, which I don't like. So I wanted to beef up the springs just a bit.
So for the front, ibwebman gave me a full set of FJ40 stock springs. Mucho appreciated!!! I took the front springs and added the military wrap wrap leaf from the rear spring, cut off the "wrap" and made the spring part of the pack. I added 1 leaf not for lift, but for a bit more load carrying capacity.
In the rear, I took stock FJ60 rear spring packs and added 2 leafs taken out(and trimmed) of the front pack, but I am going to change and use a similar approach to what I did for the front. I don't care if it rides a bit on the firm side.
Anyway, the point of this is that all the spings have different drillings and center pins, which suprised me. On the FJ40 pins, they are only 8mm. Even the front and rear have a different sized head. I drilled the springs out to 3/8 and used the Rockford pins you can get at NAPA. These are very nice center pins and appear heavier duty then stock Toyota pins. Drilling the holes larger takes a carbide tipped drill bit.
In the rear, the FJ60 springs have a 10mm center pin with a very large head. Again I drilled out the springs to 7/16, used the very nice Rockford spring pins and reassembled. Drilling springs is a real b*tch. I broke 2 $8 drill bits but in the end got it done. Spring steel work hardens as you drill, so you need a carbide bit to cut it. PIA.
Bushings---To use FJ60 springs on an existing FJ40 frame mount, you have to get creative, because with normal FJ60 bushings the spring/bushing combo is much too wide(by 1/4 inch). The solution is to use bushings with a narrow flange (.125 inch vs .265 inch). Then it's only 3 inches wide. The only combo of pin and bushing that I could make work is narrow flange 1 3/8 bushings with a 15mm hole. Then use OME 15 mm spring pins made for FJ40s. If anyone else has a solution here, I want to hear it.
So anyway, in case you were interested, there is almost no standardization among spring pins. FJ40s are different front and rear (in the length of the head), Fj40 are different from FJ60s etc. The only longer replacement pins I could find were all SAE, not metric and drilling springs even a tiny amout wider is very difficult.
