Stock Recover Points
My African Adventure is just around the corner.
The truck is already in Germany. The rally starts from Budapest a week from Saturday.
Should have delt with this while the truck was still here, but...
I have stock bumpers and recovery points. And a recovery strap that I've never used.
In a rearend pull, is it best to spread the load to the tie down eyes on either corner, or should I attached to the hoop welded to the towing bracket?
How about a front pull?
Any advice would be helpful.
Here's the final photo before I loaded the Auto Jalopy on the boat in Houston.
What recovery gear are you using? Strap size and picture if you have it. D-Shackle size and picture. Picture of the rear recovery point that you are considering. Do you still have both pair of factory tow loops (front & rear)?
-B-
B,
thanks for the resonse.
truck still has the four corner tow loops.
I don't have a D shackle. Need one?
Here's a shot of the back end.
Of interest to some, will be the 45 gallon Front Runner Aux tank. Definately not for rock crawling, but still enough clearance for overlanding.
The factory loop on the right side (partially obscured by the resonator and tailpipe) is adequate for most recovery operations. The "loop" attached to the Class-III hitch is not adequate for any recovery operations. If you need to pull from the center at the rear then use a D-shackle that goes into the 2" hitch receiver.
Typically, one would use a D-shackle to attach the tow strap to the factory loop. Where is the picture and the information (rating, length, width) for your tow strap? How are you planning to attach to the factory loops?
You should carefully inspect all 4 factory recovery points before you head out on your trip and EVERY time you plan to pull from one. They have been known to break and the resulting drama can be tragic.
-B-
I don't exactly know what sort of rallye you're about to embark on, but this is what I would want:
a heavy duty kinetic strap, such as master-pull sells called a super yanker. There are others along this line.
A pair of D-shackles and a receiver hitch mount.
Basically this kit:
Recovery Gear, Winch accessories, Winch rope = MASTER-PULL
In addition, I would carry a second heavy duty (2 or 3 inch) regular recovery strap with looped ends. And a pair of gloves stowed with the kit. Pull (or be pulled) from the receiver hitch, or be pulled from one of the factory loops up front. If you are doing the yanking, remember to only yank in drive (not reverse).
good luck - sounds like fun!
I like the look of that hitch. But I'n afraid it will add a little too much weight to my luggage for the flight.
I could bring the bolt/pin that secures the tounge to the receiver. Should be able to slip the loop of the recovery strap around it and basically get the same effect though.
Forgot to show a photo of the strap. Here's a link (2"x20' smitrtybilt)
Recovery Strap
Yes, you can use just the bolt pin. That pin and one D-shackle, and the strap you have, would be a minimalist approach. I wasn't thinking about airline luggage!
You still need another D to secure the other end of the strap to whoever is pulling you out if you are using the front loops. But, I suspect, in a rallye situation, the vehicle towing you out may have a D shackle too.
A 3"x30' strap would be much better but that one should work as long as nobody gets stuck in mud. It has loops so you'll need a way to attach the strap to your welded metal loops. That is why you need a minimum of 2 heavy duty D-shackles (3/4" minimum)
I would also recommend that Master Pull kit (or equivalent).
-B-
