Stock pitman arm taper?
Folsom, CA
I replaced the pitman arm on my 55 (Scout Steering) with one that is not bent. I need to weld and redrill the hole for the tie rod on the pitman to fit the stock LC tie rod. Does anyone know what that taper might be and where I can get the proper sized reamer? I have a reamer for 1 ton chevy tie rods, but they will not fit on the 55 with the pitman arm passing between the springs and the bottom of the frame. I know those reamers exist because Danny Warden, in the past, had drilled a pitman arm out for me. I did a search also and did not come up with an answer.
same taper, smaller hole sizes. and good luck looking for one that small. 1.5" per ft taper.
will not fit????? just use the tie rod end and tube from the wagoneer you stoled the pitman arm from? LOL.
