Stock lights AND LED lights
My 62 has had the lights replaced with LED's. I keep getting flashed by oncoming traffic thinking the brights are on even when it's the low beams. I do like how the high beams flood the night when it's appropriate. Has any one mixed them with the stock lights for lows and the LED's for highs?
After further research last night, it appears I have the Torfab lights which get high marks from fellow mudders. So maybe I should check into the alignment before I give up on them all together.
Yes. Pull up about 10-15ft from a wall or garage door. Turn them on and check the cutoff. Day running lights should have a cutoff 3-4ft high to keep from blinding other drivers. Easy adjustment with the two screws around the light housing.
I thinks it’s possible to install them upside down - so hopefully PO didn’t do that.
CD
