Stock Height
Dacula, GA
I did a little search and couldnt really find what I was looking for...sorry if it is out there and I over looked it, but here is the question....
I measured my stock height last night and it was 20 in. (center of the hub to the fender) at all four corners. Is this standard stock height or is it sagging? I am putting the Ironman Lift on this weekend and I am just curious on what to expect.
Thanks!
Nick
Here's the lifted measurements I have with the 1" rubber spacers. The spacers probably squeezed down to about 3/4".
Front Driver-------------------------------------------------------23 1/2
Front Passenger--------------------------------------------------23 1/2
Rear Driver-------------------------------------------------------23 3/4
Rear Passenger---------------------------------------------------24
Nick this is what I measured a couple days after the lift. I'm not sure how accurate it is or if it has stayed the same. I'm guessing it has probably settled some. Keep in mind this is also with the 1" spacers on all 4 corners.
Thanks guys, I guess my cruisers stance right now is quite normal. Cory, thanks for the measurements after the lift. I think I will do the same spacer setup that you did. Looking forward to this weekend.
Nick
