I am adding a rock box to my 40 (stock '78 4 speed & orion) and AA says i will have to replace the tranny output shaft. Does this mean i have to tear the tranny all the way down to change the shaft?
Mike
Mike
That is correct.
Does not matter if you do a Toybox or the AA box. Both will require a modified transmission output shaft.
Thanks for the reply Steve.
Since you are hemorrhaging money and have to tear apart a transmission to make this gearing combo work, I would seriously think about installing an H41 at the same time.
Poser,
I'm about to embark on the H41 swap you just did for chattfj40
https://forum.ih8mud.com/showthread.php?t=131979
(Excellent write up BTW!)
My setup will be minus the Rock Box. I want to have the option of a Rock Box (or one of Marlin's Toy boxes now that AA isn't going to make the Rock Box for a while) later on, when I stop hemorrhaging money. But for now doubling my low ratio and staying all Toyota is enough for me.
My question...
Where did you get the 10 spline output shaft for the H41? Or does the rock box take the 19 spline input and put out a 10 spline?
I called AA and they originally told me the 10 spline rock box output shaft can be ordered separately, and used in the H41, but when I called to place the order they thought it over again and are going to call me back. I just wondered if you had any info on this.
Thanks,
Kurt
Kurt-
I have not installed a Rock Box behind a stock or aftermarket transmission, or in front of an Orion.
I guess that if I were in the market for a crawler box, I would call Marlin and go that route, hands down.
You can buy the 10 spline tranny output from Marlin as a seperate item. I bet AA sells it also. You can't install it until you install the Toybox or Rockbox though.
That is why it makes sense to do it all at once if you plan to add a crawler in the future. Why tear it all apart twice?
Off the top of your head... do you remember which year range of the H41 was the 16 Spline? 1974-7/80 or 8/80-4/85...
In Regard to the custom bars on ToyBox & Orion Install from February, 2005...
Is that DOM?
What diameter and wall thickness did you use?
