Sting555 - 2015 LC200
So-Cal
I recently picked up a LC200 from a private seller. It’s in very good condition overall. 173k miles. I’m working on baseline maintenance and various upgrades.
Here’s my checklist of stuff I’ve done and am currently working on:
Engine Air Filter ✅ AEM Dryflow
Cabin Filter ✅ OEM Charcoal
Center Console Tray ✅ EBay
Tint ✅ Front
Spark Plugs ✅
Transmission Fluid ✅
Throttle body service ✅
Brakes ✅
Brake Fluid- Last done 1/2022 @ 93k
Power Steering Fluid- Last done 1/2022 @93k
Coolant Flush- Last Done 11/2022 @ 102k miles
Serpentine Belt/Tensioner/Idle Pulley ✅
Water Pump -Inspected
Alternator-Inspected
F&R Diff and T Case fluid Last done 9/2019 @ 67K
Replace HID Headlights *OEM Toshiba ✅
Chrome Delete door trim panels - Hyperdip
Cupholder Upgrade -Etsy ✅
HVAC re-circ door Fix-Etsy ✅
Suspension Upgrades *ready to install
  • Icon Stage 1 2.5” Lift
  • Dobinson UCA
Icon Vector 5 Wheels 17x8.5 *ready to install
Patagonia A/T Pro 285/75/17 *ordered
Hamilton CarPlay *ordered
Welcome! With that suspension and tires you must have some interesting plans for using it. Where is it going to take you? And of course, we need at least one photo.
Picture of when I picked it up
Picture post lift install
After lift wheels and tires
Other notes/updates:
- Hamilton car play unit installed. It works great. Seamless. No issues.
- After installing the lift/wheels/tires, there was some slight rubbing on front fender liners with the wheels turned in reverse. Easy fix. Removed small flaps (2 screws each side) then took out the two additional screws that attach the front of fender liner to the bumper and pushed the fender liner another 3/4 inch or so forward then secured it in position. No more rubbing. No rubbing on KDSS or anywhere else.
No immediate plans for the LC. I also have a built 5th gen 4runner which is the rig I use for overlanding/wheeling trips. The LC will mostly be used as a daily driver and for day trips, road trips, ski trips, etc.
