stiff gas pedal
I've just picked up a '94 FZJ80 and wanted to know if this was common with 80 series LCs. I've got an FJ Cruiser as well and compared to that the 80's gas pedal feels like VERY stiff. could it be a bad throttle cable?
Could be .. lube the throttle cable or buy an OEM one and change it out. The sheath on mine was beat up. Changing it made me feel better.
:grinpimp:
Second on the throttle cable. IIRC A new on is about 80.00 and takes about 15 minutes to install. Makes a huge difference.
Get it done - my wife's LX450 is sticky and (allegedly :hhmm:) is the reason she backed THRU our 4' tall white PVC fence! :bang:
$3500 damage to the 450 and $300 to the fence - $80 for a new cable is CHEAP!
When I bought my LX-450, the gas pedal was sticky....bought a new OEM one, now its smoother than silk!!!!
Just buy a new one, you will be happy. :)
I replaced my cable the other day too. Big improvement.
I wondered if anyone put any lube down the sheath? When I have replaced clutch cables on other cars in the past, an old wrench told me to squirt some motorcycle chain lube down there. Other folks have talked about puring graphite down speedo cables.
Any of this make any sense for this situation ??
Just replace it
I tried lubing my 14 yr old original cable with Tri-flow, a teflon impregnated lube, and injecting it with my "cable lube injector" until it sprayed out the other end, but it didnt help much. I believe the cable has a plastic sleeve between it and the outer sheath for "permanent lubrication" and, when it's worn, it should simply be replaced, and operated dry, which is what I'll do next.
Mine was sticky when I bought my 97. I sprayed graphite lube through the cable from engine side towards cab and cleaned the throttle body with proper aerosol cleaner and now it is perfect. Word of advice. Place rags over the end of the throttle cable in the cab or else expect black stains on your carpet. That stuff really sprays through the cable!
Quick, easy, and cheap fix.
Chris
