On my 1999 LC, i just noticed when shifting gears (automatic obviously) the gear selector sticks a little bit and then moves OK while changing gears. It's as if that long, thin plastic piece surrounding the shaft of the gear shifter is cracked, or loose or something. The shifter does move, but I have to exert more pressure to move it and hear a little cracking-type noise when it moves. Is it easy to access the area around the shifer to check that plastic piece, or see if something else got stuck under there?
Thanks.
Thanks.
