Sticking Speedometer on 98 LC
Las Vegas
I've noticed several (2?) times that my speedometer sticks at 0 miles per hour. After I've noticed, it fixes itself within several minutes. From what I remember, it fixes after I come to a stop. The only times I've seen it happen is after the LC has been sitting overnight and maybe a month apart. Any ideas?
This could be a lot of things. The fact once up stop makes be think it might be mechical related. I think it could be the speed sending unit.
The speed sending unit is mounted on the side of the transmission.
8318112020 Genuine Toyota SENSOR, SPEEDOMETER 83181-12020 | eBay
Or
Loose connection, bad wire, bad speedometer or maybe a bad solder joint on the instrument cluster.
Check the wiring connection at the speed sensor first. It is supposed to be water tight but the seals dry up over time.
