Stereo question- Factory amp.
Mesa AZ
I just installed a new JVC deck with HD tuner and Ipod wires. KD-HDR1I put in the Pioneer 6 1/2 inch speakers TS-G1641R. They installed at best buy and the guy told me at first he could not fit speaker, but with some spacers he managed to get them in behind factory grill.He ran the system through the factory amp to avoid extra charges.I think the system lacks Bass and has too shrill of a midrange.Will bypassing the factory amp help? He says only about $40 to do it.
It was my understanding that If you had the factory amp with an aftermarket that had a built in amp already. Your stereo wouldn't even work.
Anyways its easy enough to bypass the factory amp. Unscrew the glovebox so it hangs way out. Then look inside and to the right. The factory amp is there, just disconnect the wires and see if it helps. Do a search if you need more detailed instructions. It only takes 7 minutes to disconnect.
Yes. Do it yourself though, it's not worth paying $40 for.
Take out the glovebox, remove the panel in front of the pass. dash speaker, unplug the diagonally-oriented box (amp).
When I unplug either plug from amp I get no power to the stereo.
The factory amp has nothing to do with getting power to the stereo...
The installer guy hooked up your stereo really weird. To do it correctly, the stereo needs to be connected into the two extra plugs in the back of the stereo compartment via an aftermarket harness.
Toyota was smart enough to bypass the amp with those two plugs.
Bring it to me....
Not to be too forward but.....
  1. Forget about the stock wiring and speakers. They are junk.
  2. Save up for a decent amplifier/speaker combination that includes a subwoofer.
  3. After purchasing #2 above, have an experienced installer spend a day performing his magic with your rig.
  4. Get in, turn it on and have someone take a picture of the smile on your face.
There is nothing like the sweet sound of music while cruising through the woods....
WOW! I'd love to see the finished product!
X2 Do it right. Using stock anything will not be satisfactory.
It is possible my standards are set higher though. I have 800watts of power in my rig.
WRONG. MAIN POWER runs from the fuse box to the AMP and then to the headunit. A remote +12v signal runs back to the amp to power it on when the headunit powers on.
If you unplug the amp there will be no power at the headunit connectors, just leave it pluged in. However, there is another set of connectors in the dash for the oem headunit that had built in amps. Use this set of connectors to hook up an aftermarket unit. The wires tie right in with all the stock speaker wires, power is there and nothing else is needed. INFACT, the only jummper harness sold for an aftermaker to oem harness use these connectors. The jummper harness will not work with the connectors for the non-amplified oem headunits.
Seems to me your install guy sucks. You'd be better off doing it yourself. However since it was a Best Buy install, I would guess with 99% assurance they used the jumper harness I referred to. The guys don't know the wiring and assumed that by using the harness the signal was still feeding through the oem amp, but its not. Meaing your JVC deck runs stright to your new speakers, and the sound sucks because of the combo or adjustment. Well I take some of that back, I don't like JVC units, but so be it. $50 speakers, really? Don't expect so much from them. What'd you put in the back doors?
the install guy messed up or used/misused the wiring harness incorrectly. its actually really easy to do yourself.
stereo
I pulled the unit out and it looks like he used the original stock wiring harness. (Its white and the other two are smaller and Grey). So it seems like I would still be running through the factory amp. This is a powered unit 50x4.just goes to show If ya want something done right......
Ohh and the back doors. I haven't put anything in them because he said the grill mounts right to the speaker and nothing would fit without some serious modification. what have you guys been able to fit back there?... take in mind this kid looked like he was 13.
Have you had a chance to look at the factory speakers from the doors? Since there is very little clearance in the door cavities, Toyota found some POS reverse coned speakers that require very little space behind the mounting surface. The problem with that is they suck at producing quality sound.
As shown in my previous post, I avoided the rear doors altogether and installed a roof mounted enclosure just inside of the rear hatch opening. The enclosure provides enough volume for the 6.5" woofers to do thier intended job of reproducing mid-bass. In the front doors, I put my woodworking skills to work by utilizing the space in the door pocket as shown below. I also lined the inside of the door skins with Dynamat. I STRONGLY recommend that Dynamat is used on the front doors to provide a dense and solid enclosure for the front woofers.
BTW.... The bottom pic is how I started my stereo install...:eek:
Everything bear 80 said is right. I just redid my system yesterday. The big white plug is for the factory system that doesn't have an amp in the head unit and instead uses the factory amp behind the glove box. A proper wire harness (one that is labled for all toyotas from like 1987 on or something like that) has two connectors and uses the two grey ones. When using this setup it completely bypasses the factory amp. I am 100% sure of this as I wired mine myself months ago using the two plug adaptor. It worked just fine using all the speakers but not involving the factory amp. I pulled the factory amp yesterday while the stereo was playing and nothing happened at all. I had already installed pioneer sperkers in front and rear doors. Yesterday I went back and removed the dash and rear roof speakers. I think it sounded better that way. It seemed that the other speakers were just muddying up the sound. Anyhow, I also went ahead and wired up an amp and sub while I was at it. The amp is 5 channel and runs the whole system. Sounds great now. As far as putting speakers in the rear door its really easy. You don't have to take the door panel off. Just pop off the grills. Then remove the speaker with the speaker basket intact. Take the center screw out of the basket and remove the speaker. You will need a dremmel or something to cut the center frame out of the basket. Once that is done you can mount 5 1/4 speakers in the basket and reinstall. Search pioneer rear speaker install and you will find the thread for which ones will work.
stereo
So I Took it back to them and had them rewire it to the two grey plugs.at first it did not work at all, the deck just flashed on and off. then he pulled the smaller plug which he said was for the back speaker and the unit turned on and played but there was really bad crackling and it sounded horrible.the best i can figure the guy wired it wrong. I had him put it back to the old setup throught the white factory plug because at least i had some decent sound out of it. I think I am going to order the wiring harness and try it myself because these guys at best buy have NO idea. Thank for all of your inputs.If ya want somethin done right...... Now they will probably try to charge me for an hours worth of work since that didn't work. Bastards.Anyway Getting my 285/75/16 Revo's tommorow. Will post pics when its done!
Good for you taking it back.
They shouldn't charge you extra, I had an alarm system installed by them, they told me it could be uninstalled by them free of charge.
