Stereo ground question
30°54'01.53N / 84°04'56.04W
I installed a new head unit a couple months back, used the standard conversion adapters, soldered and taped all my connections and added some new door speakers. Worked perfect, no engine noise etc.
This weekend I installed two amps. One in the rear for a 10" sub and one under the front DS seat for the doors. After a couple different ground attempts using existing grounds under the console, I finally drilled a hole in the same area as the seat bolts for the ground about 4" from the amp under the front seat and am still getting engine whine in the door speakers only. Power and speaker wires are atleast 18" from one another (speakers wires run in front of the console and the power runs around the back of it...
I had one suggestion of it actually not being the amp ground thats the issue, but the hu itself. Suggestion was to pull the HU out and cut the ground connection in the harnass and direct ground the HU...After some thought, Im not sure that it would be the issue because if it was the HU, would I also not hear the whine from the sub amp too or is the sub not capable of making that high of a sound?
Any suggestions would be appreciated! BTW...the front amp is just a Pyramid 75x4. The power, remote on and ground wires are all factory connected and are all about the size of a standard remote on wire...I have 8 gauge running the power to the tiny little 16 or 18 gauge factory wire and soldered together...and have just used the factory ground to the body.
A couple things immediately jump to mind:
Multiple amps should ideally be grounded to the same ground spot. If not, you can get a weird ground loop problem that leads to this kind of strange engine noise gremlin. In a perfect world, your ground should be the same size wire as your power leads.
From a current-draw standpoint, you want to have much larger gauge wire than the 18ga. factory stuff powering the amps. I ran 4ga directly from the battery to the rear cargo area where my two amps reside, into a distribution block, then 8ga to each amp. No issues. Same wire sizes on the ground. Both amps share a common ground point.
Multiple amp installs really move the wire size and install quality a bit higher on the list of importance. At the very least, take the factory wiring out of the equation. Run dedicated power leads to both amps directly from the battery ~ 8ga at least, larger if you can swing it for the longer runs. Running 8ga wire, then soldering it to 18ga factory wire is asking for trouble and eliminating any benefit of using the larger wire.
Totally agree with the wire size contrast...but there is nothing I can do with the factory wiring. All three wires ( power, remote and ground) all feed into the side of the amp where they are connected to the board via a small rubber grommet. The amp is hard wired with the small gauge wire.
I ran 4 gauge from my battery to the dist. block that I mounted under the PS seat...then ran 8 gauge back to the rear amp that is mounted the same place the OEM amp/woofer used to be.
I then ran the 8 gauge from the dist block, around the back and under the center console and to the amp under the ds seat. Its impossible to ground to the same point without running a 8-10' cable from one amp or another...and from what I was told, you dont want your ground to be more than 24" from the amp.
Got it. That does make it tough. I was thinking you were somehow using some of the OEM Toyota wiring in there somwhere. That makes more sense.
Is the front 4ch amp fed the signal through RCA cables or speaker-level inputs? If it is speaker wire inputs from the HU, that might be the problem right there. You can buy a filter for that kind of set-up (check with local car audio shop or look online at Crutchfield) that should eliminate some of the RF interference you are picking up along the way. It might not be a ground issue at all.
In extreme cases when alternator or ignition produced whine noise has been an issue and couldn't be corrected through the common ground, heavy wires, separated wires, etc. routine, I had to resort to what's called a ground isolator which is a couple of premium grade magnetic transformers enclosed in a box which has a RCA left and right input and a RCA left and right output and is hooked between the HU and the power amp.
You should choose the best quality because if the isolator is not up to, you will notice a high frequency attenuation. By the way they are not so expensive.
Just my .02 cents
No, Front and rear channels are both RCA connected, as well as the amp in the rear.
Bacially, this amp is where the noise is coming from. If the amp(Pyramid 75x4) only has 18ga, or even 16ga wires, hardwired from the amp, it is a "chip" amp. Meaning that it has not dedicated power supply. In otherwords, it's kinda like the power of an aftermarket HU, doubled. In doining so, you not only double the power, but you also double the noise and distotion. You could try a ground loop isolator(bandaid) if you like the way it sounds(if the noise wasn't there). If you do go to another amp, get one that has terminals or connections for atleast a 10ga wire.
I hope this helps in some way. Good luck.
tONy
Here are some step by step troubleshooting techniques that has helped me in the past, good luck and hope this helps you:
How can you eliminate alternator whine in a car audio system?
If you have alternator whine in a car audio system and want to get rid of it, there is only one sure-fire way to do it. David Navone and Richard Clark from Autosound 2000 in the USA developed the following step-by-step instructions. If you follow the instructions EXACTLY, you are guaranteed to trace and eliminate the noise in your car audio system. Don’t miss a step and don’t assume that something is OK without checking it.
Each time you check for noise, you should do it with the engine running at 1500 to 2000 rpm and the headlights on full beam so that the alternator will be charging. The tests with the CD player connected should be done with a ‘zero bit’ track playing and the volume at maximum. Set your CD player to ‘repeat’ if it has that feature.
Safety. Make sure when doing noise tests that the parking brake is on and working, and that the vehicle is in neutral or ‘park’. Perform these tests in an area with good ventilation or use an extension hose on the exhaust to route the fumes outside.
Step 1. Check the Amplifiers
1a. Unplug the RCA cables from the amplifier/s and mute the signal at the input by using shorting plugs. This will isolate the amplifier from the rest of the car stereo installation. You can make shorting plugs by taking cheap male RCA plugs and soldering the centre and outer terminals together. This shorts out the input of the amplifier/s to ensure that it has zero signal.
Has the noise gone?
Yes. Go straight to Step 2. Reduce The System.
No. Go to 1b.
1b. Disconnect the speakers from the amp and connect a pair of test speakers to it. Make sure the test speakers are not in contact with the car body. The purpose of this step is to ensure proper isolation of the speakers and the speaker leads from the car's chassis.
Has the noise gone?
Yes. Check speakers, speaker leads and passive crossovers for proper isolation from the car's chassis. Shift passive crossovers to a location away from power cables and the car’s body.
No. Go to 1c.
1c. Isolate the amplifier from the chassis of the car. There must not be any electrical contact between the car's chassis and the amplifier, except for the grounding point.
Has the noise gone?
Yes. Reinstall the amplifier isolated from the chassis of the car. Make sure that the amplifier is grounded in just one point.
No. Go to 1d.
1d. Supply the amplifier with an isolated power source, for example an external car battery or a 12-Volt DC power supply.
Has the noise gone?
Yes. Noise is entering the amplifier via the power supply, try changing the grounding point and add external power supply filtering. Consider changing the amplifier.
No. The amplifier has some severe problems, is totally isolated and still noisy. Replace it or have it repaired.
That is the end of Step 1. You have now either eliminated the amplifier and speakers as a problem or you have replaced a faulty amplifier. Now you can go on to Step 2.
Step 2. Reduce the System.
2a. The amplifier is known to be OK. It is now time to disconnect any signal processors (equaliser, electronic crossover, etc.) and connect the signal from the output of the head unit directly into the input of the amplifier.
Has the noise gone?
Yes. The noise source must be either one or more of the processors or possibly the signal route. Go to Step 3. ‘Add Signal Processors’. If you didn’t have any signal processors and you are using the signal cable in its normal, installed route then the problem is solved.
No. Go to 2b.
2b. Run new signal cables over a new route between the head unit and the amplifier.
Has the noise gone?
Yes. Permanently route the signal cables in the new route. Go to Step 3. ‘Add Signal Processors’. If you don’t have any signal processors then your problem is solved.
No. Go to 2c.
2c. Isolate the case of the head unit from car's chassis. There must not be any electrical contact between the head unit and car chassis except for a single grounding point. Beware of antenna grounds and pullout cases!
Has the noise gone?
Yes. Reinstall the head unit isolated from the car's chassis and any other metal parts in the dash. Ground the head unit at one point. Go to Step 3. ‘Add Signal Processors’. If you don’t have any signal processors then your problem is solved.
No. Go to 2d.
2d. Move the head unit ground to a quieter grounding point. Test a number of points and also try grounding the head unit to the same point as the amplifier.
Has the noise gone?
Yes. Reinstall the head unit using the quiet grounding point. Go to Step 3. ‘Add Signal Processors’. If you don’t have any signal processors then your problem is solved.
No. Go to 2e.
2e. Move the head unit as near to the amplifier as possible. Then connect output of the head unit to the amplifier with the shortest possible RCA cables.
Has the noise gone?
Yes. Reinstall the head unit one step at a time. Check for noise after each step during the reinstallation. Once you have the head unit installed, noise free go to Step 3. ‘Add Signal Processors’. If you don’t have any signal processors then your problem is solved.
No. Go to 2f.
2f. Supply the head unit with an isolated power source, for example an external car battery or a 12 VDC power supply. Make sure that car chassis is not in contact with the head unit.
Has the noise gone?
Yes. The head unit is sensitive to noise in the supply voltage. Add power supply filtering to the supply voltage for the head unit or use an isolated power supply. You may be better to change the head unit. Once you have a head unit installed noise free, go to Step 3. ‘Add Signal Processors’. If you don’t have any signal processors then your problem is solved.
No. There is a serious problem with the head unit. Go to Step 4 'Check the Vehicle' and/or change the head unit.
Step 3. Add Signal Processors.
At this level the amplifier is known to be good. The car's electrical system is OK and the reinstalled head unit is working fine when connected directly to the amplifier.
3a. Connect one of the Processors back into the signal path.
Has the noise gone?
Yes. Go to 3a for the next processor. If there are no more processors, the problem is solved.
No. Go to 3b.
3b. Run new signal cables over a new route between the Head-unit and processor and between the Processor and the amplifier.
Has the noise gone?
Yes. Permanently route the cables on the new quiet path. Go to 3a for the next processor. If there are no more processors, the problem is solved.
No. Go to 3c.
3c. Isolate the processor from the car's chassis except for a single grounding point. Connect the processor ground to the same grounding point as the head unit.
Has the noise gone?
Yes. Provide isolation between the Processor and the car's chassis and permanently route the cables on the known quiet path. Go to 3a for the next processor. If there are no more processors, the problem is solved.
No. Go to 3d.
3d. Since new cables and re-grounding does not help, it is time to relocate the processor very near the amplifier. Connect the output of the processor to the amplifier with the shortest possible RCA cables.
Has the noise gone?
Yes. Reinstall the Processor one step at a time. Check for noise after each step in the reinstallation. Be careful when routing the signal cables. Remember that the car's chassis is a conductor. Go to 3a for the next processor. If there are no more processors, the problem is solved.
No. Go to 3e.
3e. Power the processor with an isolated power supply. Do not let the processor touch the chassis of the car.
Has the noise gone?
Yes. The processor’s power supply in not sufficiently isolated from its audio circuitry. Either replace it or consider the permanent installation of an isolated power supply (1:1 DC/DC converter). This type of device provides a permanent power source that is well isolated from the car's chassis. Go to 3a for the next processor. If there are no more processors, the problem is solved.
No. Go to 3f.
3f. Physically separate the processor and the isolated power supply from the rest of the system by many metres. Use long signal cables.
Has the noise gone?
Yes. Something is seriously wrong with either the processor or your install/test procedures. Please repeat this level from the beginning.
No. Change Processor -- this one has design problems. Go back to 3a for the new processor.
Step 4. Check the Vehicle
The suspect car's charging and electrical systems can be checked by using the previously installed sound system in a "known quiet" car.
4a. Connect jumper cables between the batteries of the two vehicles and start the engine of the suspect car. Turn on the headlights on the suspect car and listen to the stereo on the "known quiet" car.
Is there now noise in the quiet car’s system?
Yes. Have a qualified auto electrician check out the car’s charging system.
No. The suspect car's alternator and charging system is now proven to be quiet. The problem must lie in the car stereo installation -- not in the vehicle.
