Before i start this i just want to make sure i have everything right.
The plan is to install 30mm spacers on top of my front springs to level out the ride.
1. Jack up front end of the truck by the frame or bumper and remove two front wheels, support on jack stands.
2. Disconnect the front shocks from the bottom shock mounts. This allows the axel to articulate (hopefully enough) to allow enough room for the spacers to slide in top of the shocks.
3. using a floor jack, jack up on side of the axel enough to allow the other side to droop down and leave enough room to slide in the spacer.
4. repeat for the other side.
5. re-attach shocks.
6. Install tires and hope the ride is right on!
Does this sound like the easiest way to do things??
