Steering wheel shaking question.
I replaced the steering damper and the shaking is almost gone, except slight freeway turns - just like you Sc0-. I also took the damper off and tried driving. Shaking was awful, but as soon as I put in a new damper it all disappeared (except for 60mph slight highway turns). So I think I put a temporary fix in place. I also tried rotating tires and it did not change much.
Something to consider regarding the steering stabilizer is that you should be able to run in normal conditions w/o the stabilizer. Stabilizers are there for out of the ordinary situations such as hitting a pot hole or something at speed. If you have a problem like this, the stabilizer is not going to be the issue. All you've done is to put a bandaid on it. The old stabilizer was worn out thus you feel the shimmy that shouldn't be there if all is right with the truck. Putting the new one on controls the shimmy but the forces are still there and will prematurely wear out your new stabilizer.
Good advice here. I've driven my truck without the stabilizer, barely noticed. The stabilizer is masking the underlying problem which needs to be fixed.
Good news is that you've bought yourself some additional time to figure out the issue.
X2, you did not fix the problem, just hid it.
My daughters fj62 has started skaking at 50-55.Seems like it is coming from the rear. Need to look into it this weekend to get it ready for the trail ride in March. MIke
It could be wheel balance, but the OP stated they were just balanced. For the front suspension, my first step is to torque the arm bolts, panhard bolts, knuckle nuts to spec. If none are loose inspect the bushings.
I had the tires rotated and balanced and that fixed my problem :D
Bought the life time rotation and balance with road hazard warranty from Americas Tire.
Thanks Tools
I replaced my shocks about two months ago. I got the original Toyota shocks for my truck. I am looking into replacing my tires (I have stock Michelin tires on now) with some all terrain tires. I hope with new balanced tires the shaking will go away.
If it doesn't .. I am gonna stick with my initial guess .. one or more tires out of round. :)
So if replacing his tires doesn't help the shaking, you think that it is because his current tires are out of round.
I'm confused.
nothing to be confused about .. I am an idiot! Clearly not thinking when I posted.
sorry!
Any upates Rasta?
