Steering - TOO much play!
Colorado Springs, CO
Hello fellow mudders! I have a vexing steering problem on my 97 FJ80. My steering wheel has excessive play in it and the front end seems to "hunt" when hitting uneven spots in the road. Here's what I have done: New steering stabilizer, tie-rods okay (no play in them), trunion bearings okay, wheel bearings repacked.
The steering wheel gives 30-40 degrees of play either side, which can make for interesting driving when it is windy at high speeds. Any suggestions? Thanks for your time...
COCruiser
Any suggestions?
Could be a bad steering box but you'd better hope not as they are quite spendy. I have read there is an adjustment though I have not done it or read up on it. As I recall, it will take out a tiny bit of steering slop but it is worth a try if your only other option is buying a new box. Try a SEARCH and see what you turn up with as I know this has been discussed in 1 or 2 other threads. Suggested keywords: steer*, box, sector, play, slop* (Some combination of those should get you something worthwhile to read.
-B-
Have you tried adjusting steering free play as per FSM? :popcorn:
You can get a good idea if the play is in your steering box with 2 people. One turns the steering wheel back & forth. Second person, (the more mechanically skilled) stands with open hood (or bonnet) and with right hand and arm grabs steering shaft between firewall and steering box and with left hand on front wheel below him. Have first guy turn steering wheel back and forth. The "hands" guy should be able to feel and possibly see if that's where the play exists.
