Steering question.
Southern NH
Last week I had a stock '78 FJ40 and the manual steering was, well.. like you would expect.
Last weekend, I put 2.5" spring lift and some 33" tires on it and drove it around for a while. Now, it is a really wild, swervy, and wobbly ride.
Everything is tight uderneath the truck (I checked and re-checked) and there was not much to screw up during the installation. I am guessing that this is probably a common issue that happens whenever we raise the center of gravity of a vehicle AND double the magnitude of tire it is rolling. I have some questions, though.
What should I do next?
Would an alignment tighten everything up at least back to normal?
If I did spend the $1K+ for power-sterring, would it make my steering rock-solid?
Any other suggestions would be greatly appreciated as well.
Do a search on "caster" or "death wobble" or "steering". Unfortunatly, you will have to unbolt your springs again to add this little baby below. You might have some driveline vibration if you don't have these in the back also. Some do, some don't. Have fun, been there.
http://store.yahoo.com/coolfj40/shimsspring.html
Steering slop will be exaggerated by the lift, but can also come from the steering box itself, the pitman arm end, tie rod ends, the center arm assembly, improper toe-in, castor angle, and who knows what else. Installing power steering won't necessarily cure any of it if the slop is downstream from the box.
I would start with castor angle, toe-in, and work through everything until it was nice and tight.
HTH and good luck.
I had the same issue with a 4" lift for the first week or so when I got my junk. Then like an idiot, i decided to check the tire pressure. turns out, the PO had like 40lbs in 33x12.50s. I ened up taking them down to about 20-25 IIRC and it was 100% better. I would try that first. it was cool to drive the cruiser w/ one hand.
I did the mr manny steering toe adjustment too, worked great. I would say do this and see what you come up with.
edit: the first thing i bought for my cruiser was those shims. never needed them after the said adjustments. pm me if you need a set. the are just taking up space in the garage.
