- Joined
- Jan 6, 2003
- Threads
- 64
- Messages
- 1,216
Another wandering steering related question, but this is a question about the tie rod ends. I apologize if it's been covered, I searched and I've only seen this asked once before, but there was no response to it.
I have a 1975 40, with the stock steering, and an approximately 2.5" lift. Because of the lift, the drag link comes down at a slight angle from the center arm to the passenger side TRE. It's not a very extreme angle, not enough that I would normally consider it a problem. However, when trying to diagnose my loose steering issues, I saw what could be a the source of my problems. Because the drag link is connected directly to the tie rod at an angle, when I turn the wheel back and forth, the tie rod wants to also pivot up and down a little bit before actually transferring a side to side force to the wheels.
Is this normal behavior on FJ's? I've checked all my other connections from the rag joint to the TRE's to the tires, they all seem ok, but my steering still doesn't seem responsive enough. When I'm parked, it feels fine, there's not too much play at the wheel. But when I'm driving, it feels much looser, and I suspect that it's something that only happens under load. Does everyone else's cruiser behave similar? Aside from getting a high-steer arm or other modifications, anything I can do to minimize this?
