Steering pop / clunk
Good evening. I am currently on a road trip from Texas to the Southeast and am currently in Charlotte NC. We went off-roading at Durhamtown a few days ago and I noticed a pop / clunk in my steering after the day’s adventure. When the tires are neutral, if I turn the wheel left about 10 degrees, there is a slight delay then a clunk and it continues to turn. Same thing if I turn the wheel all the way right and am coming back left. It sounds like it is coming from the driver’s side, and possibly the steering box. Today I put it on jack stands and without the engine running went back and forth with no pop/ clunk. Then with the engine running same thing, no noise. Only when the vehicle is on the ground does it make the noise. It is not the steering stabilizer, and yes my tie rod ends need replaced, but don’t believe this is the issue here. Any and all advice is very welcome as usual. Thanks in advance!
Check yer nuts!
Seriously, though, check the 4 steering arm nuts on the bottom each knuckle.
May or not be your culprit, but good to check anyway.
sounds like when my steering arm nuts backed of in moab let us know what it was pictures always help
Is it a single clunk or multiple clunks? Check your nuts as stated. When was the last time it had a birf job?
  • Like
Reactions: RFB
shiite didnt even think of it. good call
Steering arm nuts meaning Tie rod end castle nuts?
It is a single clunk.
New Longfield Birds were put in in November, and I remember those dreaded repeating clicks.
Bushings on radius arms meaning bushings on the tie rod ends?
Thanks again for all input.
I am still learning all of the nomenclature for my 80, so thank you for the patience and the explaining. Those bushings should be good to go, we’re replaced a few years back with the caster correction bushings. Will give them a once over tomorrow morning though. Also will be checking all castle nuts. That clunk seems to happen when going slow and over a bump on the driver’s side as well. We will focus on the steering clunk though!
The steering arm nuts are on the bottom of each knuckle. There are four of them on each side. Get down and look on the innner side of the tire, at 6 o'clock. Look up the tire sidewall towards the steering knuckle. See the four nuts there? Those guys.
BigAxe- Checked those yesterday when I arrived at destination and two were loose. After that all 8 were checked and re-tightened. Thank you for clarification:
Thinking of also lifting each side up and tightening them down. Maybe each tire being up would relieve pressure and allow me to tighten them further.
radius arm bushes could be flogged out after a few years depending on your use, and on the type of bush used. Poly caster correction bushes don't last long if used offroad.
if its not the steering damper, and not loose knuckle stud nuts, it could also be trunion bearings, particularly if knuckle studs were loose.
if you put the front up on stands, and remove the tierods so you can rotate each knuckle separately by hand, you'll be able to eliminate or confirm trunion bearings as an issue
  • Like
Reactions: RFB
All bearings were replaced in November when I did a front knuckle rebuild. Both wheel and trunion. I don’t think they are bad, but anything is possible. Thank you.
Listen to this man, even if he has a funny accent! :grinpimp:
That clunk seems to happen when going slow and over a bump on the driver’s side as well. We will focus on the steering!
Everyone has given good advice, especially since we are not there. I'm not saying we're right, but don't dismiss this advice. They are part of the steering, as part of holding the axle in alignment (front/rear motion). And can Clunk/pop when worn out and going over a bump slowly.
If you use jacks/jackstands/blocks in a "safe manner" on the frame and let the front end/axle hang freely. See if you have any play or can grab a hold of the radius arm to see if there is play in it, also check over the bushings on the panhard bar. Good luck!
:deadhorse:
so THAT'S where front end front clunk came from
Search for that thread.
On the second page you'll find all the torque values for the front and rear suspension stuff. I posted pics from the Factory Service Manual.
The lateral control rod, or panhard, gives some people the pop/clunk when the bolts loosen.
- Have U checked ALL 12 / for that matter ALL 24wheel LUG Nutz to see if 1 or more is loose ? u simply may have a Loose Alloy or steel wheel ?
- Also , Check your 2 ft brake calipers , there 4 dowell pins & the V clip that holds them in , U could have like broke a front pad off its metal block ?
start with basics
btw, Please define your ( days adventure ) , how it may relate to your new clunking noise / feeling u have o_O
