Steering knuckle grease
Jacksonville, FL
How do you know when you have enough in? I have just finished rebuilding the knuckles and have filled the area with the plug, moved the wheel and filled it again. Since the inner axel seal keeps oil out, how do I know I am not pushing grease past it? My grease nozzle fits just right with a flexable hose, but I don't know if the grease will push the nozzle out or just go past the seal.
You will be hard pressed to 'over fill' the knuckle with a grease gun...but I guess anything is possible...
If you just finished rebuilding the knuckles, you should packed them with Moly grease, and really should not need to be greased through that fitting...
I put twenty shots or so into the knuckle when I grease the chassis during a service...
Did you not fill the knuckle half full as described in the FSM?
Good luck!
-Steve
Yeah steve, I packed as much as I could around the birfield, but nothing outside of the ball, I figured the grease port would take care of that. Also, the FSM doesn't give instructions on packing the birfield. I pretty much packed mine like a wheel bearing, then moved it in circles and paked it some more. Any problems with that?
I am sure that many people have done it that way.... I like to knock them apart, clean and inspect them, but I have been called anal too...
You will not get grease on the other side of the knuckle that does not have the pipe plug fitting if you did not put grease in the outer cavity.... I always fill the outer cavity, and then 3/4 fill the rest of the housing after the axle shaft is installed, just before I install the spindle.
You will probably be al right, as long as you are not going to go swamp your truck right away....
Good luck!
-Steve
