Steering joint welding question
West Frankfort Illinois
Hi,
I am doing a Scout PS conversion. I have a '71 which means I have the older steering shaft. I have ordered the plate that mounts to the firewall, and I have a collapsable shaft that will mate to this shaft with a steering U-joint I bought from Flaming river. The collapsable shaft is 1" in diameter, and the '40 steering shaft is very close to 3/4". I ordered 3/4" DD to 1" smooth and I ground the ro shaft to make it fit the DD opening. My question is this: The steering knuckle is "CNC Machined Billet Aircraft Steel". I picked this joint from a list online because it would fit the steering components I had. I am not sure if I can weld this type of material. Can this material be welded to regular steel? Anything special I should know about it?
Contact the manufacturer or dealer of the part and ask what alloy it is specifically, then post back up. Chances are though, yes-but may be very different than what you are used to.
does the flamming river have the little allen head threaded lock with the nuts to keep it in place ? my borgesen joints did but i went all DD shafts with chevy column and i just drilled a small hole ( not all the way through) for the allen head locks to fit in and added some red loctite and thats all that holds mine on the colaspable shaft. its been 3 years and they havnt come lose yet . i dont know if this will work on round stock though!
I drilled and pinned all my steering together. Weld will make it harder to repair later.
Don't try to weld the flaming river u joints.:frown:
The bearing seals melt and run out, trust me on this one.
The DD will have an allen head set screw with a jam nut.
For the round side I put the whole she bang in a bench vise and drilled two holes at 90° through the u-joint into the column shaft, then I tapped the holes for a #10 screw. I used allen head screws and jam nuts to put it together.
What method of welding did you use on your U-joint Bustanutley? I would Tig it personally, but know that is not an option to everyone.
I put it in the drill press tonite. Slow and steady and one dull bit later I had a nice hole through the u-joint and the 1" shaft. The U-joint even came with a pin for just such an undertaking. It worked out very well. Thanks again everyone for the advice. BustaNutley, I also believe a good weld would have been fine, but I am just an amature welder and I don't trust myself to weld on something my life depends on. So instead I will trust it to some locktite and allen set screws :)
