Steering "Drift" or "Play"
Ok. Thanks. I'm learning! Thanks guys.
Everything looks good. I guess I'll have to tighten up the steering box. Thanks
URGENT! Do a check under the right front knuckle to make sure you have all(4) studs in the bottom of that knuckle! (Trunnion Bearings) What you are describing is almost the same as what I had on mine with a loose steering arm on the bottom of the right knuckle. Mine had one broken off stud, two had already fallen out, and the fourth was extremely loose. My wheels could almost turn independently of one another. If this arm falls off, your wheels go in opposite directions and you will have no control of EITHER wheel.
CHECK IT IMMEDIATELY!
Wish I had read this a couple off days ago.
Saturday afternoon my wheel felloff, turns out to be 2 missing and 2 broken knuckel bolts.
No warning before hand. No missing bolts at last oilchange.
Now they have got treadlocker.
It happened right outside my own driveway while almost standing still.
