steering dampner problems
Canby, Or
so I installed my OME lift this week end.... well most of it. :)
I cant seem to get the steering stabilizer off? whats the deal?
I also had a bolt break off of the rear bottom shock mount that doubled the install time! I had to completly drill it out and retap the hole to 1/2".
And I havnt even started the caster correction bushing job yet!
any suggestions??????
:cheers:
The damper will come off. I used a pickle fork, BFH, mapp torch and profanities. It gave a good 20minutes battle but gave in. It was messy. Installation of the new one was cake walk.
pickle fork
ya.... I was thinking I might need a pickle for and some more profanities! :)
thanks.
Tie rod end puller and a BFH. Came off easy once you tighten the puller then smack it a couple times. The have the puller for free loan at Autozone.
If you haven't already damaged the bushings on the steering stabilizer, and if it's still in good shape, I wouldn't replace it. :meh:
I did notice a difference between the stock and OME damper. IMO its a cheap upgrade esp. if you have sitting in front of you and just have to curse a little for the install.
I didn't notice any difference but I always like looking at it.
x2
Heck, I barely noticed a different with no steering dampener....
