steering damper ??
San Jose CA
Getting ready to replace TREs and am trying to wrap my head around everything. Seems fairly straight forward with a few bumps likely to happen. But I ran into some confusion with steering dampers
I seem to have two
One hefty one from the frame to the drag link. That seems to be the "norm".
But there's a second one from the left hand side of the tie rod to the right hand side of the axle.
Steering has always been acceptable, only doing the replacements due to zerk fitting failures.
Some folks don't seem to indicate a need for dampers, others say it's a cushion for system shocks.
So, ditch the tie rod one and stay with the OEM looking one, or....
The top one is OEM. I'm guessing the PO added the other aftermarket stabilizer to control wander (or death wobble). Either one will do the job if the rig is close to stock and front end is set up correctly.
What size tires are you running?
FWIW, I don't run a steering stabilizer.
