Steering damper hardware
Chandler, AZ
Anyone know where I can get just the mounting hardware? The OME that is currently on there has the studs/bolts built in. I am trying out a Doetsche and it didn't come with anything. Something like pic below for our rigs.
Think a lot of people ditch the tapered factory bolt and use just any regular bolts that fit.
Oh ok. I didn't know if the tapered were required. Makes sense, just has to hold the thing in there.
Monroe sells a kit but second what Q says. Grade 10 would be my choice.
Thanks @LS1FJ40. Being lazy right now, do you happen to know length and size?
Thanks @Qball as well.
Don't know if you figured this out yet but the passenger side (damper hinge) bolt is 100mm (4") long minimum and the driver side is 70mm (2.75") long minimum.
Yep I did get it worked out. Actually 3.5" works. Maybe FZJ's are different than FJ. Thanks though.
