Steering Column Swap
Utah
Has anyone converted an early 72 steering column with a 72 or later model steering column? If you have, what if any problems did you have?
Thanks in advance
Scott
You will need to fab up mouting at the firewall, as they are very different....later columns have the turn signal-high/low beam switch and ignition in the column, so that wiring will need to be adjusted also.
Good luck!
-Steve
I don't mind the fab work, but I was hoping for a bolt in. I guess I couldn't get that lucky.
Thanks
