Steering causing engine stalling
Hi guys last time i was offroad something weird happened in my 80
When ever i had some pressure on the drivers wheel (right hand side)
The engine would try and stall out with revs going up and down but once no pressure on the wheel its fine..Note it only happenes to drivers side....but once im back on the road its fine. Am i correct in thinking it could be power steering pump on its way out
Ok so i decided to disconnect the iac valve to see if anything happened and when i disconnect it while car is running nothing happens would this mean that it is buggered....
I pulled it out cleaned it and the port reinstalled it then tried again did same thing..
Did you put any load on the engine which would change the idle speed? When you disconnect the IAC (stepper motor) it does not move, reset etc. so you should expect no change unless the load on the engine changes.
Ok problem is solved and fixed....after having 3 different mechanics go over it...i found when checking intake pipes for leaks was a torn intake pipe .....replaced it and runs sweet again.
NOTE TO SELF
Dont go back to those mechanics hahahah
